[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: WebHandler vs REST project - basic questions
  • Thread starter Thread starter Sanjeev Reddy
Sanjeev Reddy
Hi Marek, Yes, if you check that checkbox a catalog file will be created with schema and operations information, the same file will be used while creating client apps (KUIB, Kendo UI, Rollbase etc...) via JSDO. Hope this helps, Sanjeev
