[progress Communities] [progress Openedge Abl] Forum Post: Re: Using Values In List From...
  • Thread starter Thread starter Santosh Patel
Santosh Patel
Explanation: Ordering by createdAt (descending) and limiting max rows for the query to 1 ensures that we receive the latest entry in the ledger. The where clause 'id!={!id}' ensures that we do not take into account the the ledger entry being created (note that we are using after create timing which means the record is already available) Steps to follow on the ledger object: Note: This approach does not let you mass update and make existing record entries in order. Create an 'Update field value' trigger, say "Update Opening Balance" timing: after create field to change: opening balance Formula code (change integration names for fields accordingly): var result = rbv_api.selectQuery2("SELECT Closing_Balance FROM Ledger where id!={!id} order by createdAt desc", 0, 1); var prevClosingBalance = 0; if (result.length > 0) { prevClosingBalance = result[0][0]; } if (prevClosingBalance === undefined || prevClosingBalance === null) { return 0; } else { return prevClosingBalance; } Create an 'Update field value' trigger "Update Closing Balance" timing: after create field to change: closing balance Formula code: return {!Opening_Balance#value} + {!Credit#value} - {!Debit#value};
