C
cwright
Peter, That is really a question of semantics. You should put those file into your SVN repo that you wish to have version control over. All of your source code is a good start. Any control files your application requires should also be stored. If you plan on doing any Continuous Integration / Delivery, then all files that are required to build and run your application should be stored in the a repository. You do not have to store everything in the same place, nor does it have to be in the same projects but it should be stored somewhere. If you have multiple developers working on the same project I would recommend you NOT store the .project .dbconnections files. These files are developer specific for PDSOE. When using Subclipse in PDSOE, there are some files that are automatically not included (Eclipse control files). This can be a good thing or bad depending on your application. Regard, Cameron
