H
Håvard Danielsen
The bug is caused by the introduction of a .NET wait-for in PDS, which conflicts with some of the functions that are handling some of the saves from Dynamics' tooling. You can set an environment variable PDS_WAITFOR = "ABL" before PDS is started to make it use the standard Progress wait-for. This should allow you to save Dynamics objects without these errors. The problem using the ABL wait-for is that the Visual Designer (for .Net) and the Appbuilder Designer will stack their wait-for statements if opening both type of designs in the same project. If you then close them in a different order than they were opened problems will occur.
