P
Patrick Tingen
If you are using Total Commander, then you should look for the progress pl plugin. It treats procedure libraries like a zipfile and with the plugin you can treat the .pl file like a file folder, including viewing files and copying files from the .pl progress-tools.x10.mx/plplugin.html
