Jeff Ledbetter
Hi. When using Eclipse/PDSOE, the /Task_XX directory is the Task/Lab directory. Eclipse requires that the resources exist within the Eclipse project. To make sure that I understand, in the classic GUI you are specifying the same directory (per user) for each Task? In the past we've bounced around the idea of using just the project directory as the Roundtable Task directory instead of creating individual 'Task_XX' directories under the project (this would be a user-preference). Although that may create some limitations, it sounds like that kind of functionality would solve your issue as there would just have to be the single PROPATH entry that would have to be maintained (like what I think you described). Would that resolve your issue? In the meanwhile, I have some work-around ideas (possibly). Question: are the PASOE instances on each developer's machine, or a central testing appserver machine?
