[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Using client certificate with soap request/enabling ws-a addressing
  • Thread starter Thread starter dheeraj.gupta
dheeraj.gupta
1) I can access the wsdl document without using the -wsdlxxx options.. not sure why these parameters are used and if they should be used.. but instead of -sslxxx options when I tried with -wsdlxxx options, it gave the same result. Can you please suggest how to turn on the debug options for SSL/TLS connections in ABL. I have generated that with the help of soap-fault object handle.
