[progress Communities] [progress Openedge Abl] Forum Post: Re: Using Ado.net For Db2...
  • Thread starter Thread starter alambu
alambu
Hello, Regarding the Question in previous email, Are you still facing the issue in retrieving the columns from SSIS using DB2 ADO.NET (DDtek.DB2)? Does your issue with ProviderDescriptors.xml is resolved? Regarding the Question related to the mappings, To try this out, I need following information, Which Data source your using for the Source data source? Can you provide us the schema of table you are trying to work on, this will help us try out this complete case, and not just focus on TIMESTAMP issue alone. Thanks, Amith
