L
Laura Stern
I agree with Stefan whose "biggest challenge is the syntax". The functionality is clear. But the usage of the syntax is not. Where do you use the word BIND and where BY-REFERENCE? i.e., On which side of an INPUT or an OUTPUT parameter do you put each keyword. What are the combinations that are allowed on the different ends of a procedure/method call? Do you need BIND on one side and BY-REFERENCE on the other, or is it just one of those, and which one for INPUT vs. OUTPUT. And also on one side the TT or DataSet should be defined as REFERENCE-ONLY. This is not clearly documented anywhere that I know of. I have tried to do this myself and usually fail to get it to work! Jeff or Peter, if you know how to use this, please contact the content (e.g., documentation) team and give them a list of the rules so they can document it
