I
Irfan
We Provide Swagger for OEManager API's and I think it provides ample documentation. Once you know which API's you want to use, you can choose either REST API's or JMX to automate them. David has given an example of using REST API's in this thread. If you would like to do it using JMX, then you can use OEJMX. Documentation to enable Swagger for OEManager - docs.progress.com/.../Enable-Swagger-UI-for-management-REST-API-access.html Documentation for oejmx utility - docs.progress.com/.../Use-OEJMX-to-manage-and-monitor-an-instance.html An ABL Session can have more than 1 threads and so an ABL session can have more than 1 ThreadID's. It is only useful for us to debug the Multi-Session agent. For your context, each ABL session can be tracked by its session-id and agent-id. But if you would like to monitor requests that are getting executed on that MS-Agent, then RequestID would be the key to debug. Please enable Swagger and look at the API's in "AgentManager" section and see if any of them matches your case.
