[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Trying to connect to running db in progress explorer
  • Thread starter Thread starter Matt Baker
Matt Baker
A knowledge base search turns up this: 000019474 knowledgebase.progress.com/.../P192166 Indicating you have a DNS configuration conflict with your hostname. You're running 11.7.0. You should install 11.7.3. At the very least it will clean up the CONTENT SECURITY POLICY REPORT warnings in the log file. The "The operation completed successfully" coming out of the database broker has been there for a very long time. It indicates a problem connecting to the adminserver when started as a managed database. Is this a laptop? Can you post the ads0.exp file (from same location as admsrev.log file)? This has full stacks for the error messages which might give a clue as to what is failing.
