James Palmer
If I'm reading you correctly, the issue is that the database was started by some means other than the explorer, so explorer isn't aware it's already running. Am I right? If so, then you'll want to first shut down the database. Assuming you're running on Windows, start the proenv tool, and navigate to the physical location of your sports2000 database. In that directory run "proshut sports2000 -by". Give it a little for the database to shut down, and then in progress explorer try starting the database again. If I'm barking up the wrong tree, could you please give a bit more background, such as OS, Progress version etc, and try and redescribe the problem.
