[progress Communities] [progress Openedge Abl] Forum Post: Re: Trigger Not Running With...
  • Thread starter Thread starter jniemi@vyco.com
jniemi@vyco.com
Hello, Have you tried adding the delete process to a server side trigger and then use the rbf_runTriggers() call from the client to perform the delete? I don't know if it will work for you or not, but you might be able to use that as a work around to ensure the triggers fire before/after delete.
