K
Ken McIntosh
Hi, What was the return code from http? There is a known issue when the 204 code is returned which is caused by the httpclient code causing a timeout while in an infinite loop in the httpClient code. This was logged as defect# OCTA-15336 and is in the hotfix process for 11.7.5 at the moment. If you're getting a 204 return code you may want to contact Technical Support to report this and verify you're experiencing the same issue. Ken Mc
