[progress Communities] [progress Openedge Abl] Forum Post: Re: Source Management Solution :...
  • Thread starter Thread starter Mike Fechner
Mike Fechner
Thanks, Jeff! Von: Jeff Ledbetter [mailto:bounce-jeffledbetter@community.progress.com] Gesendet: Freitag, 21. April 2017 20:50 An: TU.General@community.progress.com Betreff: RE: [Community Groups - General] Source Management Solution : Deployment / Build / Technical Impact Analysis ? Update from Progress Community Jeff Ledbetter Hi. I suspect that your customized UI is limiting your access to all Roundtable TSMS features. Out of the box, Roundtable TSMS provides Cross-reference and Where-used views for your ABL source-code and schema that tell you what Objects related and how they are related. In fact, I don't know of many tools that can provide you with this much information with a single click. This screenshot (Roundtable TSMS 11.6) is from our plug-in but the same information is available in our GUI client as well. The Roundtable Automation Toolkit is a framework to integrate Roundtable with Jenkins and provides some pre-built scripts to integrate the two tools with a templates to create your own. It can be found on our Downloads page: www.roundtable-software.com/.../ The documentation resides here: https://confluence.nodeable.io/display/ARAT One could use the Roundtable event hooks to replicate data into a third-party code-motel like SVN. The event hook documentation can be found in the rtb_events.p procedure. A white-paper on using our event hooks and API can be found here: http://www.roundtable-software.com/roundtable/resource/pdf/wp/HooksAPIforOA.pdf All Roundtable TSMS documentation can be found here: http://www.roundtable-software.com/support/documentation/ To discuss your requirements in more detail, please contact me directly. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here . Flag this post as spam/abuse.
