V
Vimalkumar Selvaraj
Hi, I am guessing you are using NewUI. If so as per doc rbf_showOrHideField() method takes three arguments. First one is fieldName , second argument is true/false decides whether to show Field or not, third argument is true/false decides HideResponsiveColumn or not. So your code should be var code = rbf_getPicklistCode(fieldName); //Pass the field integration name of your picklist field //Show Monthly Income Pension field if code is "Yes" otherwise hide it rbf_showOrHideField("Monthly_Income_Pension", (code==='Yes'),true); There is a syntax error at your code in the second line, there is extra comma at the end and close parenthesis missing. Let me know if this works. Thanks, Vimal
