Santosh Patel
Unfortunately, the search icon button and create buttons do not have tab stops. You can put in an enhancement request to allow tabstops on supplementary buttons on fields. I suggest using the following javascript snippet to allow you to workaround this. $('.rbs-rel-selector.rbs-with-create input').on('keypress', function(e) { if (e.ctrlKey && e.charCode === 0) { var createButton = $(e.target).closest('.rbs-editField-valueContainer').find('button > span.k-icon.k-i-plus'); if (createButton) { createButton.click(); } } }); With this script running on page load, you can press "Ctrl+Space" to open up the related 'Quick Create' popup if create button is present on the field.
