[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Script for enabling/disabling quiet points for snapshots
  • Thread starter Thread starter George Potemkin
George Potemkin
proquiet exits only when db broker did its part of job and when it talked back to the dbutil: [2018/01/19@18:16:47.289+0300] P-3224 T-1788 I DBUTIL 5: (5569) Quiet point request login by George on CON:. [2018/01/19@18:16:49.087+0300] P-732 T-9484 I BROKER 0: (5583) Quiet point has been enabled by the broker. [2018/01/19@18:16:49.292+0300] P-3224 T-1788 I DBUTIL 5: (453) Logout by George on CON:. [2018/01/19@20:01:16.418+0300] P-11204 T-1164 I DBUTIL 5: (5569) Quiet point request login by George on CON:. [2018/01/19@20:01:16.641+0300] P-732 T-9484 I BROKER 0: (5584) Quiet point has been disabled by the broker. [2018/01/19@20:01:17.420+0300] P-11204 T-1164 I DBUTIL 5: (453) Logout by George on CON:. If return code is nonzero then you can run proquiet again immediately. Anyway the communication between dbutil and broker will /always/ take 1-2 seconds.
