[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Schema Maintenance in SQL Server (Comparing "Pro2SQL" vs. "SQL DataServer" products)
  • Thread starter Thread starter gus bjorklund
gus bjorklund
> On Dec 16, 2019, at 9:18 AM, dbeavon wrote: > > is it forcing you to resync more often than you would otherwise because ROWID's are changed? rowid's do not change for the life of a record.
