Roger Blanchard
IF the S22.imap.dll is not in the GAC then you need to copy it to where your assemblies folder is. When you defined your project you tell it where you assemblies.xml folder is located and this dll should be in the same folder. I typically create an Assemblies folder under my project root folder and put the assembles.xml in that folder as well as all the dll's that are not in the GAC.
