[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Rulestest is running partially
  • Thread starter Thread starter Harold-Jan Verlee
H
Harold-Jan Verlee
A ruletest references a particular rulesheet or ruleflow you'd like to test. If you want to test a collection of rulesheets, make sure your test topic is a ruleflow. Based on your input data, your rules in this ruleflow will execute. Make sure each individual rule is documented, in other word, provide a rule statement which is linked to your formalized rules. Also make sure these rule statements are provided with a post instruction and proper alias reference. In your test you'll then see which rules were hit by your data just be monitoring the rule messages which were generated. If a rulesheet doesn't execute, make sure that your filter criteria are set properly. Sometimes you may inadvertently filter out parent entities, because child entities don't survive the filter. As a result, no data survives for your rules. Let us know if this works for you.
