[progress Communities] [progress Openedge Abl] Forum Post: Re: Replication Using Pro2...
  • Thread starter Thread starter Dmitri Levin
Dmitri Levin
>Pro2 compatible with Open Edge 11.6 RDBMS with Enterprise edition Yes. >Is there any trial version of Pro2... Please contact Progress Software. I believe there is no trail. But I am sure Progress could make something for you, >Database size does matter for Pro2 It does not matter. I have 1.3 TB database, though I replicate only about 5% of it, The size of the database will affect only the initial push ( Bulk Insert ). And if you replicate only some subset of tables then the size of that subset will matter. The size of the tables that you do not replicate does not matter. The performance of replication after the initial push will depend how often replicated tables change. You can estimate that by looking at _TableStat VST.
