[progress Communities] [progress Openedge Abl] Forum Post: Re: Replication Sets.
  • Thread starter Thread starter Jeff Owen
Jeff Owen
Hi Jason, The first step would be to configure and enable AI on both targets. Once this is done, you can enable The configuration as a Replication Set in the Transition section of the properties files. I’ve put properties for source and both targets below that provide an example of a Replication Set property file configuration. -jeff Source properties: [server] control-agents=agent1,agent2 database=db0 agent-shutdown-action=recovery defer-agent-startup=5 transition=manual transition-timeout=5 [control-agent.agent1] name=agent1 database=db1 host=localhost port=6600 replication-method=async critical=0 connect-timeout=120 [control-agent.agent2] name=agent2 database=db2 host=localhost port=6500 replication-method=async critical=0 connect-timeout=120 [transition] replication-set=1 database-role=reverse transition-to-agents=agent1,agent2 restart-after-transition=1 start-secondary-broker=0 normal-startup-arguments=-S 51876 source-startup-arguments=-S 51876 -DBService replserv target-startup-arguments=-S 51876 -DBService replagent [agent] name=agent0 database=db0 listener-minport=4387 listener-maxport=4500 First Target’s properties: [server] control-agents=agent1,agent2 database=db1 agent-shutdown-action=recovery defer-agent-startup=5 transition=manual transition-timeout=5 [control-agent.agent1] name=agent1 database=db0 host=localhost port=6600 replication-method=async critical=0 connect-timeout=120 [control-agent.agent2] name=agent2 database=db2 host=localhost port=6500 replication-method=async critical=0 connect-timeout=120 [transition] replication-set=1 database-role=reverse transition-to-agents=agent1,agent2 restart-after-transition=1 start-secondary-broker=0 normal-startup-arguments=-S 51877 source-startup-arguments=-S 51877 -DBService replserv target-startup-arguments=-S 51877 -DBService replagent [agent] name=agent1 database=db1 listener-minport=4387 listener-maxport=4500 Second Target properties: [server] control-agents=agent1,agent2 database=db2 agent-shutdown-action=recovery defer-agent-startup=5 transition=manual transition-timeout=20 [control-agent.agent1] name=agent1 database=db1 host=localhost port=6600 replication-method=async critical=0 connect-timeout=120 [control-agent.agent2] name=agent2 database=db0 host=localhost port=6500 replication-method=async critical=0 connect-timeout=120 [transition] replication-set=1 database-role=reverse transition-to-agents=agent1,agent2 restart-after-transition=1 start-secondary-broker=0 normal-startup-arguments=-S 51878 source-startup-arguments=-S 51878 -DBService replserv target-startup-arguments=-S 51878 -DBService replagent [agent] name=agent2 database=db2 listener-minport=4387 listener-maxport=4500
