[progress Communities] [progress Openedge Abl] Forum Post: Re: Recommendation To Downgrade...
marian.edu
Alex, if the compiler can ‘digest’ the s**t there is no reason not to generate r-code - I don’t think there is anyone out there that would like to be either forced to fix all warnings or simply shift them all together, time constraints will make the second option be the only valid choice anyway :( Marian Edu Acorn IT www.acorn-it.com www.akera.io +40 740 036 212
