[progress Communities] [progress Openedge Abl] Forum Post: Re: Read-xml / Write-json
  • Thread starter Thread starter xjg
X
xjg
Hi Peter, Thanks for your answer. That's my suspicion too but I would like to use the READ-XML method without passing to it an schema definition, everything in the process is working pretty good but this conversion.. I have a workaround for this situation but I would like to know if I was missing something and I could somehow define the type of the field for a given set of fields, that's why I tried the field-type-mapping option but including this parameter is not showing any change..
