P
Peter Judge
You can use the PARENT-ID-RELATION depending on version. Check out the doc for more. PARENT-ID-RELATION [ data-rel-name ] FOR parent-id-rel-spec Specifies that: · The relationship between the parent and child buffer is based on the RECID of the parent record when reading from or writing to an XML document or JSON string. · The child rows of a Pro DataSet buffer are nested within their parent rows when the Pro DataSet data or schema is rendered to an XML document or JSON string. · The child RECID field is not serialized.
