jniemi@vyco.com
Unfortunately, this is a known limitation of the setLookupFilter API. I'm not sure if there is an idea out there to allow the filter to work on picklists. Depending on your use case, you may be able to use a picklist and a dependent picklist to get your filtering in place. When we first started using Rollbase, we used the picklist on a lookup quite a bit. Over time, we have moved away from it and back to the selector style due to the filtering and adverse performance of the picklist option. The entire recordset on a picklist is loaded when the page is loaded. This is why it can't be filtered using the standard API and if you are trying to filter the list, it probably has enough records where you are seeing performance degradation due to the loading of the records on page load.
