C
Charles Ford
Hi Jorrit, We're interested in an answer. A cumbersome workaround we have used is to place the text of the template into hosted files (typically these may be header, body, footer of the documents) and then place the token expansion in the template. Move the hosted files into another application and have your users then update these instead (typically this application is undeployed). I think making a copy, deleting the original and 'relinking' to the new, either on the dev or prod side, would still suffer a reset of the link at each deploy but maybe this saves overwriting the users edited template (worth a try?!) Thanks -- Charles
