[progress Communities] [progress Openedge Abl] Forum Post: Re: Psc00350688 - Issue With...
  • Thread starter Thread starter Garry Hall
Garry Hall
Hotfixes are an accumulation of urgent fixes on a release. You don't just get that particular fix, you get fixes for many other bugs as well that have been pushed out for 10.2B08. The decision on whether to update your Client Networking install (and whether to rebuild r-code) would depend on what is addressed in the hotfix, and whether you are suffering from anything that was addressed. There is no hotfix installer, and the range of bugs addressed can be very large, so it is hard to identify each specific thing you might need to address when installing the hotfix. The notes at the end of the hotfix README are intended to alert you to the things you might need to do in order to deploy the hotfix. The particular bug you are concerned about (PSC00350688) would affect only db servers and self-service clients. You should review the list of bugs addressed in the hotfix.
