Sanjeev Reddy
Hi Robert, In 11.6 PDS OE increased memory settings for 32 and 64 bit versions. Some customers running 32 bit version of PDS OE seems to have problems with this setting. Please decrease -Xmx value in eclipse.ini file and restart PDS OE. Default is 1024m, set this value to 768m or 512m. You can find eclipse.ini file under ${DLC}\oeide\eclipse folder. I think in you case it will be available under C:\OpenEdge116\oeide\eclipse (observed from below screenshot). After changing these values, restart PDS OE with clean option. Hope this helps, Sanjeev.
