We never update the database except in pre-compiled r-code. Thomas had pointed out the primary reasons for compiling things dynamically at runtime. Those are the same reasons we have uncompiled programs in our ERP too. I'm not really sure how to remove that "query/results" license from our productoin or pre-prod servers and test the behavior of "OE Application Svr Ent". I typically only work on the development servers (using PDSOE and the like). Once we are in the process of setting up "Pacific Prod AS for OE" I will test it without "query/results" and then follow up with another test after "query/results" is applied (I'm assuming that the second tests are going to allow our uncompiled ABL to start working again, after initially failing the first tests). As far as I am aware we haven't used the source "encryption" in production for a number of years. If I remember correctly, we once used the default encryption key for our internally deployed ABL applications but don't do that anymore.
