rgromadk
It depends on examples. Bprowsdldoc shows what we define in procedure order..p, For example for example 2 Parameters ApplicationArea This value is defined as an XML Schema string value. DataArea This value is defined as a DATASET-HANDLE. result This value is defined as an XML Schema string value. Best regards Rafal
