[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Problem with the position number for fields
  • Thread starter Thread starter Jeff Ledbetter
Jeff Ledbetter
Hi. "Why does this happen.." This value is generated by the db engine when the field is added to the physical schema. Since the fields may have been originally added in a different order then the order in which the Schema Update routine applies them, the values may end up being different. "... is there any way to prevent it?" One way to work-around this would be to write a routine to programmatically generate and apply an incremental DF file to the other target databases (the PSC Kbase has some examples of calling the OE routines) and then call this procedure from the "updateSchema" event hook that fires after the schema has been updated.
