David O'Regan
Brian, I have just tried running it with the parameter you suggested and, indeed, it does show quite different results. Using this method I can see that it specifies an output parameter to get the response data (not sure why I don't get this without -show100style) and using the ns0 namespace as you suggest seems to help. I am still getting an error but I think that's because I haven't yet got to figuring out how to set the content-type to the required value using this method. I'll play with this a bit more when I get time and see if it works with the correct content-type. I will probably just use the system.net.webclient method for the time being since it's working correctly and is simpler to implement. I just don't understand why this works but my first example doesn't... Thanks for your assistance. David
