B
Brian K. Maher
David, You can use the HTTP methods if you want, its just that the Web Service support is normally easier. Have you tried running bprowsdldoc with the -show100style parameter? That may get you something different. One common mistake people make when using the Web Services support is to use the XML format specified by the vendor instead of what bprowsdldoc shows. For example, vendor documentation may show sample XML with specific namespaces whereas bprowsdldoc will show the same with with the ns0 namespace. If you use the vendor formatting things will fail but if you pass what we tell you to pass it will work. I work in support and have seen this mistake numerous times. Brian
