[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Problem when running HTTP request from ABL procedure.
  • Thread starter Thread starter Akshay Guleria
Akshay Guleria
You can also set environment var "SSLSYS_DEBUG_LOGGING=5" which will generate SSL layer logs for an ABL client. You can find the log "cert.client.log" in you work dir and it can help you to investigate any potential SSL handshake issues that is creating problems
