[progress Communities] [progress Openedge Abl] Forum Post: Re: Problem Of Installation
  • Thread starter Thread starter Ramon Schouten
Ramon Schouten
Abir, The error you had at the beginning was that you were trying to import the Application, with relationships to 'Certification', 'Leads' and 'Prospects', whilst the application does not contain the Object from where to get these relations. For short: The Application didn't know where to get the lookup fields or related fields from. The solution for this is adding them to your dependent or core objects. Add to core objects if; The object will be used in the Application, but does not already exist on the new environment. add to dependent objects of; The object will be used in the Application and already exists in the new environment. If there are no relationships needed with those certain objects, just delete the relationship in the object definition and delete them from dependent and core objects. These are the requirements for Exporting to XML. Though, i think you already solved this problem. If I am right, you now have a problem with importing the XML file to the new environment. So, you cant install the new application from the XML file. If you could send an image of the overall install screen (so the image you posted before, but then with the entire page showing) I would have a much better idea of what the actual problem would be. Greetings, Ramon
