Rajkumar Mateti
Hi Abir, if you are really using the certification, Lead and prospect objects in your application then generate application XML adding those objects as Core objects from application definition edit page. If not remove them from Dependent objects of application definition edit page. Hope this helps.. Thanks, Rajkumar
