V
Valeriy Bashkatov
Hi Satya, Many thanks for this instruction. Now I understand how this works. Indeed, this need to be simplified ))) But now I have another problem. After logging in on the Pro2 Web page, the data does not load. In the server log of restbroker1 I see Procedure: 'callForData DataProcReq.p' Line:66) DataProcReq called for Dashboard/tableBehavior with the parameters [ 4/10/2018 4:07 PM|4/20/2018 4:07 PM|5 ] (Procedure: 'callForData DataProcReq.p' Line:66) DataProcReq called for Monitor/qQryWeb with the parameters [ ? ] (Procedure: 'jReq/Dashboard/threadLoad.p' Line:29) ** The month of a date must be from 1 to 12. (80) (Procedure: 'callForData DataProcReq.p' Line:66) DataProcReq called for LogViewer/getLFNames with the parameters [ REPL_LOG ] (Procedure: 'jReq/Dashboard/tableBehavior.p' Line:31) ** The month of a date must be from 1 to 12. (80) In my $ DLC / startup.pf, use "-d dmy" parameter. But in the procedure a date is passed as a parameter, which does not correspond to this format. It is possible to somehow fix it?
