[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Pro2 - upgrade dbs from 10.2b to 11.7
  • Thread starter Thread starter goo
goo
What I describe would not work anyway, since any changes done since first load will not be taken in consideration. Ok, I will try that solution you are saying, that would be much easier. I probably need to make a backup/restore of SQL schemaholders as well, and load new .df into Repl databases (since we have a newer version of Pro2 on the new server). If I remember correct, there was some changes.
