[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Pro2 multi-tenant OpenEdge db replication using CDC
  • Thread starter Thread starter jokilval
jokilval
Okay maybe I will contact Progress about this. The documentation is the Pro2 5.5 Configuration guide that came with Pro2 installation (in docs directory) as Kunal stated. I don't think it is available online as it came with the Pro2 installation. The documentation regarding multi-tenancy is about setting up a secure connection to a multi-tenant database. It states that I need to create a separate folder for each tenant. It is not stating anything about CDC and I just assumed that it would also work with the same logic using CDC.
