[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Pro2 multi-tenant OpenEdge db replication using CDC
  • Thread starter Thread starter Valeriy Bashkatov
V
Valeriy Bashkatov
Hi, As far as I know Pro2 does not currently support multi-tenancy (as well as tabplepartitioning). This is because the _Cdc-Change-Tracking table is not a multi-tenancy table. You need to contact with this task to a professional service of Pro2. >>The documentation says that I should have two separate installations of Pro2. By the way, in which documentation you found about this? Can you post link? Maybe something has changed and I don't know about it yet.
