[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Pro2 6.0 installation missing bpAdmin.w
  • Thread starter Thread starter Satya Prasad
Satya Prasad
Starting from Pro2 Version 6.0 there is no support for the Admin tool. This means, all old .w files were dropped off from the installer. Also Pro2 v6.0 will work for both OpenEdge 11.7 version. As Valeriy said, you need PASOE license to run the interface (which is the replacement of Admin tool) The Pro2 installer .exe will do the PASOE instance creation, application deployment and property updates automatically. Post install, update the running database(repl, replperf) details in bprepl\Scripts\replProc.pf file and start the PASOE instance. Once the instance started, hit this Login URL @ http:// : /pro2 Thanks, Satya
