[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Pro2 4.6
  • Thread starter Thread starter temays
temays
If two of three tables are working, then my suggestion on -cache is not your issue. Are you running compression triggers? If so, do you have an old un-applied queue record for the same table/rowid combination? If yes then you would not see a new entry show up, the trigger would simply update the un-applied queue record and not create a new one. Terry
