[progress Communities] [progress Openedge Abl] Forum Post: Re: Possible Implications With...
  • Thread starter Thread starter mollyfed
mollyfed
Unless the code that is being compiled is using something that was added in the hotfixes and so won't be supported in the earlier releases, I don't see that there will be an issue. In fact, Unless I am mistaken, I believe you could compile in say, 11.6 and use it in 11.3 (there is a brief exception window in the OpenEdge 10 timeframe when 32bit and 64bit rcode didn't mix). Hope this helps. TIA Molly
