Michael Jacobs
You can find some reference information for configuring a sessionStartupProc in the OE ABL Service Developer Guide's Session Startup procedure topic. One of the key points is that the startup procedure runs as an ABL persistent-procedure. Meaning that it and its stored variables are accessible for the lifetime of the ABL session ( or you explicitly delete it ). What goes into a startup procedure is obviously your choice, but for my simple testing purposes I do things like: . define global variables - which I can later access from other parts of my test application . create objects and store them locally in the startup procedure - which l can later access from other parts of my test application while executing client requests . Initialize static classes . load application properties . initialize my session loading and use of OE Domains . initialize application logging . log startup summary information ... It is really very flexible and useful. Now, the real ABL developers out there may tell you that some things I do for testing are not appropriate for a real application - and you should follow their suggestions. But this simple list may give you some idea about what might be done. I'm sure others can also help by sharing their uses.
