[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: PASOE Performance Issue with NEWING class
  • Thread starter Thread starter Roger Blanchard
Roger Blanchard
>> If you watch your system resources, can you verify that this is running with 100% CPU utilization (or at least it uses the single-threaded equivalent of 100% CPU)? If not, then there are other unknown factors and resources that may be participating in your repro. It only uses 25% of CPU. >> Also is there only *one* PASOE session that is active in the agent while you are running your repro? Our tests were when NO other sessions were active. On the live site we did this at 2:00am when the system was not being used. We ran the tests after a reboot. In our office using the customers DB we only had one session active. >> Or perhaps your new PASOE server has a virtualization problem that might be short-changing you on CPU. Maybe you should run both versions of your tests on the same hardware - this will take the hardware and virtualization out of the equation. I ran the same test not using a VM with same results...22x slower.
