[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: PASOE concurrency problems in tcman command
  • Thread starter Thread starter gus bjorklund
gus bjorklund
> On Mar 14, 2018, at 2:01 PM, dbeavon wrote: > > Given the fact that tcman env takes about a second to run and is run quite frequently . . . is there some reason for why you run tcman quite frequently? while you should not be running into the problem you observe, there should also be no good reason to run it frequently.
