[progress Communities] [progress Openedge Abl] Forum Post: Re: Pas Trial License Issue...
  • Thread starter Thread starter Matt Baker
Matt Baker
OEE can get out of sync with PAS if you used command line to start/stop instead of using OEE to start/stop. Some of this was trying not to call tcman so often from AdminServer. This is same issue as related to the performance and CPU overhead of tcman/powershell you asked about in other thread. Since the CPU issue was addressed in 11.7.2 by avoiding calls to tcman, the AdminServer is a lot more aggressive with polling to check on PAS running/not running. This should be pretty much fixed now.
