[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: PAS instance (11.7) does not appear in the Explorer connection when creating a server o
..oops I meant the prior version is 11.6. Also, I realize now that the "UNKNOWN" status that you were seeing before is probably just an indication that you had not deployed oemanager yet. This is probably not actually a "critical" problem after all, only an inconvenience when you are trying to use the OEE console. I think that having accurate details (eg. version = "UNKNOWN") about the behavior of PASOE is dependent upon the presence of the "oemanager" webapp. I've heard that, in theory, you can run PASOE in production without oemanager (***PS) ... but I don't think it would be worth the trouble and I think you would lose a lot of diagnostic and management features. Out of necessity we have been monitoring agents and sessions and memory usage on a regular basis. (We are currently working with tech support on our second memory leak support case that involves the current PASOE msagent in 11.7.5) Good luck, David *** PS. For that matter, in theory you might be able to run PASOE without the *entire* adminserver/ubroker framework. At that point you would lose the OEE console and you'd lose the ability to do messaging via the "generic JMS" adapter. I doubt many customers would take things that far. You might save a bit of memory, but it would cost you quite a lot in terms of diagnostics and management.
